I am using a standalone 4 pin molex 12/5v power
supply to power the KFLOP/KANALOG wherein I use the 12v
side to power limit switches using the kanalog opto
inputs.
As its comes from the factory this power supply has a
3 prong cord that connects the 12 and 5 returns to earth
ground. If I leave this connected then the kflop return
will be connected to earth ground. The USB shell and
USB return are connected in the small form factor
computer that I am using. It does not get earth ground
from any other source, but will through the kflop via
the USB shell.
The kflop/kanalog return is also connected to the VFD
and drive units but neither of these connections is
common to earth ground unless it gets to earth ground
through the kflop.
So the question. Should ground the kflop (and
computer, drive and VFD electronics) to earth through
the KFLOP power supply or should I isolate them by
leaving the ground unconnected to earth.
